C4 Europe
Page 2 sur 2 • Partagez •
Page 2 sur 2 • 1, 2
Re: C4 Europe
Bonsoir Olivio77
voila à quoi correspond ton VIN
Date de construction 19 Avril 1993
VIN: 1G1YY23P2P5114944
VIN Decode
1:U.S. BUILT
G:GENERAL MOTORS
1:CHEVROLET
YY:CORVETTE & CONV
2:TWO-DOOR HATCHBACK LIFTBACK (07,08,77,87)
3:ACTIVE (MANUAL) BELTS W/DRIVER INFLATABLE RESTRAINT SYSTEM
P:ENG OPT - LT1 DISP - 5.7L CYL - V8 FUEL SYS - MFI DIV - 1,2 PROD IN - U.S.
2:CHECK DIGIT
P:1993 MODEL YEAR
5:BOWLING GREEN KY
114944: PRODUCTION SEQUENCE
RPO Codes
1SB = PACKAGE-OPTION 02 (1SB)
68U = EXTERIOR COLOR,PRIMARY,BRILLIANT RED MET (68U)
793 = TRIM COMBINATION LEATHER,RUBY RED LEATHER TRIM(793)
79I = INTERIOR TRIM,RUBY RED INTR TRIM COLOR(79I)
AC1 = ADJUSTER,SEAT,6-WAY POWER,BUCKET,PASSENGER 6-WAY PWR P/SEAT ADJR
(AC1)
AC3 = ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR
(AC3)
AJ3 = RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
AQ9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT
ST,LUXURY(AQ9)
AX4 = RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) FRT & RR
MAN RST SYS FOR EUROPEAN VEHICLE(AX4)
B4H = MODIFICATION-NOISE CONTROL, EXPORT MODIFICATION-NOISE CONTROL
(B4H)(EXPORT)
BAG = PARTS PKG EXPORT PARTS PKG(BAG)
BGR
C18 = ARM AND BLADE,WINDSHIELD(BLACK) W/S ARM & BLADE(C18)(EXPORT)
C68 = AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO
ELEC CONT(C68)
CF7 = ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
D7A = GEAR-SPEEDOMETER DRIVEN (25513042) (D7A)
D8K = SENSOR-VEH SPD (10456091) (D8K)
DC8 = MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL ELECTRIC,BREAKAWAY
(PAINTED)(55 INCH FIELD OF VIEW) O/S ELEC R/CON PAINTED MIR(DC8)
E5Z
E9Z
EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT
(EXP)
FE1 = SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)
FX3 = RIDE AND HANDLING,ELECTRONIC CONTROLLED ELEK RIDE & HANDLING
(FX3)
GM1 = AXLE,REAR,2.59 RATIO 2.59R(GM1)
IL3 = TRIM,INTERIOR DESIGN INTERIOR TRIM DESIGN(IL3)
J55 = BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)
KG9 = GENERATOR,140 AMPERE 140 AMP(KG9)
LT1 = ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
MAE = MARKETING AREA EUROPE(EXPORT) EUROPE(MAE)
MD8 = TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD AUTO TRANS
(MD8)
MX0 = TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) AUTO
TRANS PROVISIONS(MX0)
NA5 = EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
NK4 = STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
QB6 = WHEEL 17 X 8.5 FRT, 17 X 9.5 RR, ALUMINUM, STYLED STYLD AL WHL(QB6)
T90 = LAMP,SIGNALING AND MARKER(EXPORT) SIGNAL & MARKER LAMP(T90)
U19 = SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19)
U1F = RADIO,AM/FM STEREO,CASSETTE,C.D. PLAYER,ETR,BOSE,INCLUDES CLOCK
CASSETTE/CD PLAYER(U1F)
U52 = CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
U75 = ANTENNA,POWER(CHROME) PWR ANT(U75)
UL2 = RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2)
UX0 = SPEAKER SYSTEM,SIX,DUAL FLOOR SILL,DUAL EXTENDED RANGE SAIL
PANEL 6 SPKR SYS(UX0)
V78 = VEHICLE STATEMENT(DELETE)(EXPORT) V78)VEHICLE STATEMENT-DELETE
VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING
LABEL USED OUTSIDE U.S. AND JAPAN(VC5)
VD1 = PROVISION OPTIONS,EUROPE(EXPORT) EUROPEAN PROVISIONS(VD1)
VG9 = PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9)
XAA = TIRE FRONT P255/45ZR17 BL R/PE ST TL HW4 TIRE OPT(XAA)
YAA = TIRE REAR P285/40ZR17 BL R/PE ST TL HW4 TIRE(YAA)
Z25 = APPEARANCE PACKAGE 40TH ANNIVERSARY(LIMITED EDITION) 40TH ANNIV
(Z25)
VIN Decode
1:U.S. BUILT
G:GENERAL MOTORS
1:CHEVROLET
YY:CORVETTE & CONV
2:CHECK DIGIT
P:1993 MODEL YEAR
5:BOWLING GREEN KY
RPO Codes
(AC1)
(AC3)
ST,LUXURY(AQ9)
(B4H)(EXPORT)
BGR
ELEC CONT(C68)
E5Z
E9Z
(EXP)
(FX3)
(MD8)
(Z25)
Mimi77- Silver Star Heroes
Nombre de messages : 4694
Re: C4 Europe
Je vais confirmer tout ça.
Mille mercis, Mimi77 ! !
Oliviou77- Supercharged
Nombre de messages : 956
Modele Vette : C4-4OTH anniv
Re: C4 Europe
Tiens, tiens ?Donca a écrit:A l'arrière, les feux latéraux blancs sont des feux de recul.
Pourquoi les supprimer en France ? ça n'en serait que plus efficace, déjà que ceux de la plaque d'immat éclairent à un mètre...
Re: C4 Europe
Les miens fonctionnent (c'est une européenne) et je trouve ça original mais surtout très utile.
edencars- Membre Honoraire
Nombre de messages : 4234
Re: C4 Europe
Merci de l'info.
Je vais vérifier ça.
Re: C4 Europe
"EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT (EXP)"
Denis ZR-1- Membre Honoraire
Nombre de messages : 5306
Re: C4 Europe
C'est donc cette option qui comprend toutes les modifs pour l'Europe ?
Re: C4 Europe
Pour les feux de recul il faut simplement que tu les rebranches, ou voir pour remettre des ampoules, souvent c est enlever pour l homologations. J ai tout remis a l origine US après avoir eu la CG.
david- Red Devil Army
Nombre de messages : 3238
Re: C4 Europe
J'ai vérifié, ils fonctionnent ! Je n'avais pas fait attention...
Merci des tuyaux !
Merci des tuyaux !
Page 2 sur 2 • 1, 2
» Eurock climbing : Le tour d'Europe des sites d escalade
» Championnat d'Europe FITA : Rovereto (ITA)
» Boeing 737-73V Europe Airpost F-GZTC le 10.05.10
» [Europe 2010-11] Les clubs français en Coupe d'Europe
» Championnat d'Europe de débardage à cheval 18 et 19 juin (71)
Page 2 sur 2
