Bonjour à tous
+51
Matess67
Bacticool
Djdick77
eco
Keg
BenVette88
Vettefab
Ultor128
Youk
Arnaud 57
DjoeV8
stingray454
vince53
GhosTSharK
ENZO55
alainZO6
MathC3
Tarzag
gegeboy
DreamCorvette
manvette
Z51
bluesun
need 4 speed
Stephen
Lilly la Diva
pepyxx
PIERRE 29
ricco
Triba
gallou36
Thierry133
le loup
santiago
stingray1972
papounet
Jack Panzica
55 participants
Page 28 sur 29
Page 28 sur 29 • 1 ... 15 ... 27, 28, 29
Run out of Posi Unit
Gary Ramadei is putting the final touches on the rear end he is building for me. He discovered excess run out in the posi unit. Here are his comments and process to reduce run out to his specs.
Hi Jack,
So as I mentioned yesterday there was a wide range of lash in the setup. I wanted to see if it was in the gears or the posi case. I removed the ring gear from the posi and checked the bare posi in the housing. I checked a few places; the posi flange where the RG mounts, the case OD where the RG ID is press fit, and the flange OD. I found the case OD was good with only 001" or less runout in it but the flange had 006" runout and the flange OD had 008". The flange OD doesn't matter but the case OD & face do. I set the posi up in the lathe using a small 4 jaw chuck to dial in case OD as my reference. I dialed the case OD to less then 001" and rechecked the flange run out in the lathe and it was out 006". I faced the flange 005 in small passes and turned the flange OD. In the lathe they were both 0 but I knew it would open up in the housing because it will be referenced off the case bearings.
"I found the caps were loose on the bearing races and set them up to 001" gap. Then I installed the bare case and found the flange runout 002 which is good. The case OD is still 001 and the Flange OD is under 001". I was able to keep the case bearings installed without issue. The lash is now within 002-003 compared to 006 before. I couldn't do a pattern test because I have to let the Loctite setup on the RG bolts again. Next up I will check the pattern to see how it looks. I did radius the edges of the teeth on the RG, this is an old blueprinting trick.
I will see how the pattern looks on Monday."
This video is an example of what he did to my unit. Just click on it
[url="https://www.youtube.com/watch?feature=player_detailpage&v=3rDWhaGtr3E"]1963 Chevrolet Biscayne Positraction Differential Overhaul - Part 3.1 - Repaired - YouTube[/url]
Pictures
On milling machine
Caps
Hi Jack,
Pictures
On milling machine
Caps
Jack Panzica- LT1
- Nombre de messages : 319
Modele Vette : 1966 Glen Green Roadster L-79 350 HP
Rear End Installation
Well I celebrated Memorial Day Weekend with a little car work. I now have all the parts ready for installation .
The first thing I have to ask is , Why did I think I could do this ?
Next I had to get the transmission back in . Replaced the throw-out bearing, rear bearing and seal. Never easy...I finally resorted to the push the tail over the cross member, roll the tranny on to my chest, and do a push up with it . It went up and in. No problems but a lot of back and blue marks on my arms and body.
Drive shaft hooked up with new slip yoke
Using a jack, I lifted up the rear with cross member and bolted it to frame
Next the haft shafts...using jacks to lift the TA up to level to install HS
Next up the strut rods and spring later in the week, waiting for parts
Jack Panzica- LT1
My rear end is back in the seat again!
Bonjour !
My rear End is in the seat once again......The first ride of 2015.
After 6 months of restoration , the car held together for a 20 minute ride to start the break in of the newly rebuilt rear end, transmission and suspension..
I did the removal and installation with the car on jack stands.
I do not recommend this method , but like many of us, I had no choice..,,,,,,,.
I have to go now....time for another 20 minute ride....
If you click on the link you will see the video of my first ride, looks better on computer then Iphone , speakers for sound
https://www.youtube.com/watch?v=pUH1jXM_FaE&list=UUKuWDoeSH2rC2AIHAwAs3Ow&index=1
Jack Panzica- LT1
Re: Bonjour à tous
C'est reparti pour au moins 100 000 miles !
Bravo Jack !
drive2
Bravo Jack !
drive2
Denis ZR-1- Coup de Cœur C.P.
- Nombre de messages : 7816
Re: Bonjour à tous
What a great job you have done , Jack. You must feel much better than a few month before. How is you mood ? I know the answer
Alec- Turbocharged
- Nombre de messages : 31588
Re: Bonjour à tous
Alec a écrit:What a great job you have done , Jack. You must feel much better than a few month before. How is you mood ? I know the answer
Bonjour Alec,
I feel great and have been going to the gym and bike riding.....heart is strong and feels much better now that I got the car back on road.
I still have a lot of little things to fix.....
Hello to Michelle
Jack
Jack Panzica- LT1
Re: Bonjour à tous
Thanks for the news about yourself , more important than your car.
Take care , you have to visit us with your wife , don't forget.
Michele will have your hello , she's at work at the airport.
On vous embrasse
On vous embrasse
Alec- Turbocharged
Re: Bonjour à tous
Hello Jack,
Very nice job!!! Maybe you can join us on the 25th of july at Sinclair Maine at the Long Lake Sporting Club! We are going there with my fellows Corvetter from Quebec city
Keg- Blown
- Nombre de messages : 1497
Modele Vette : c6 2008
Big Blocks in the Dakotas
QUOTE=66BlkBB;1590018414]Jack,
Hi, I thought you would like to look at a few big blocks that a few friends in the Dakotas have. Dan, Maroon, Pete , Yellow, and Steve , Black big blocks. I had lunch with them as I crossed the Dakotas on my 48 State Tour.
Steve asking me a question on my linkage post.
"Are you planning any more US excursions? Dan, Pete and I still own the BB's. Dan just got his repainted and setup with a new rear spring, steering box, etc. I haven't seen it yet but will try to look at it when I am in Moorhead again. Take care."
Steve[/QUOTE]
Hi Steve,
I prefer the GM rods, I was not sure if I could use them, or if in fact they are the ones that have worn out.
I am planing to go to Carlisle this year. I have never been to it , more info later as I am finishing up the rear end and suspension on the car.
Thanks again for the great lunch....
Some pictures of my visit on the 48 State Tour
Back on the road
Steve[/QUOTE]
Hi Steve,
Back on the road
Jack Panzica- LT1
Re: Bonjour à tous
Bonjour
et merci Jack
ils peuvent bien avoir le sourire , MAGNIFIQUES ces Corvette !!!
bonne journée
et merci Jack
bonne journée
titus50- Turbocharged
- Nombre de messages : 8474
Re: Bonjour à tous
Hi Jack , say hello to your friends , great job also to keep thoses grannies in good shape
Alec- Turbocharged
The Car is Packed and Corvettes at Carlisle Awaits
Bonjour !
The Car is Packed and Carlisle awaits ! I am planning to attend Corvettes at Carlisle this August 27-30, 2015. I plan to be on the road for about 14 days. ( August 14th to Sept 1) [/B .
Even though I have owned my car for 45 years, I have never been to Carlisle. I hope to have a mini reunion with many of my hosts from the 48 State Tour. Let me know if you are going !
]If you have owned your corvette for 30 or more years, I would like to stop by and add you to my research on long time Corvette Owners.
The map shows the general route (not roads yet) I am taking, PM me with your town and I will put it on the map. Once the map has enough dots on it.
I will plan the actual route. More information to come as I add details and dates of travel. I used this method to travel to all 48 states, and Europe to document these cars and owners. I will be posting to 9 US and European Corvette Forums as well as Facebook. Here are is a link to my web page with details . of my trips to Europe and NCRS National Convention.
www.corvettevagabond.com
[B]Map link- Just click on it. PM with your town and I will put your town on the map . The route shown is just a general direction. Actual roads traveled later. ( I will not post your address , just town)
https://www.google.com/maps/d/edit?hl=en&authuser=0&mid=z2su_20EvonU.kBQFfkdm4LN8
Jack Panzica- LT1
Re: Bonjour à tous
Hello Jack , have a look at the post " anniversaire".....in "Cool Cruise Corvette Saloon" subject ....
Alec- Turbocharged
Plans for Carlisle Corvettes Trip
Bonjour to All
Here are some plans for my trip. I plan to leave ME on the 20th, Stop in Mass to see 58-67 cars from 30 year owners.
21st, Stop at Ed Johnson shop ,Bridgewater, MA work on car and stay over with Ed.
22nd, Sat. Head west toward Ohio, Stops in western NY ? Please let me know if you have a car you want me to see
23rd, Sun , stay with Midyear, Ohio,
24th somewhere in Ohio / PA, Let me know if you want me to see your car,
25.PA...Near Pittsburgh area....Let me know if you want me to see car.
26 Pitt with Son,
27th head to Carlisle. 28-29, First Time attending
30-31 Pitts with son,
Sept 1-4 DC-MD, NJ, NY, MA and Home
I will start to fill in stops as I get calls to stop. If you have owned your car for more then 30 years...I would like to add you to my photo collection...for that book that we all have been waiting for.
I hope to see many of the hosts who had put me up on previous trips. I will be posting some pictures of my last trip over the next few days.
My cell on the road will be 207-838-5695 or post online to forums or jackpanzica@gmail.com
Some members from the 48 state trip
26 Pitt with Son,
Jack Panzica- LT1
Re: Bonjour à tous
who's that lovely woman ?
Jack , we will be in NYC from october 8th until october 12th.....
Alec- Turbocharged
Re: Bonjour à tous
Alec a écrit: who's that lovely woman ?
She was a host for me on my 48 State Trip.....NYC in October......How knows......we may come and say hello.....
I worked for the last 7 weeks and am now done....working on car for Carlisle trip...I hope you have had a good summer...the tourists will be gone soon....
Jack
Jack Panzica- LT1
Bonjour to all, Just in case some of you are in the US here is my travel plans.......lol....I hope to post great pictures of my trip and photos of good looking girls....oh...I mean cars......so here is an opening post.
Enjoy Jack
Hi , travel update.
I will be in Lexington MA around 10 am on Thursday, August 20, 2015. It will be my first stop on my way to Carlisle via Ohio.
I am stopping to see 58 and 67 Corvettes that that have been in the family for more than 40 years. If you have a C-1 or C-2 and would like to say hello and have me add it to my Corvette Vagabond documentary on long time owners.
If you live in the Boston area and want to joint the fun for an hour or so PM me for details.
From Lexington, at 12 or 1 pm , I head to Bridgewater , MA , Ed Johnson's shop get my car on a lift for last minute fixes and inspection for the trip. If you live south of Boston , PM me for details if you want to say hello at Ed's place.
Jack
On my last trip I was treated to this little jewel owned by a host in Louisiana. I hope to see your special car ....PM me to see if you live on route.
This baby lives on Cape Cod , MA
Enjoy Jack
Hi , travel update.
Jack
Jack Panzica- LT1
Re: Bonjour à tous
Hi , you can post good looking girls pictures as well it's not a problem for us
Alec- Turbocharged
Bonjour to all and here is more info , I wish it was about travel in France.......but.....maybe next year...
I will leaving ME tomorrow Thursday, 20th, heading for Lexington MA, and Bridgewater MA.
Work on car in MA and leave Friday ,21st for Columbus , Ohio.....
Leave Ohio for Parts unknown on Monday 8/24 Tuesday 8/24
Leave parts unknown for Pittsburgh , stay with son, 8/26
Leave Pittsburgh on 27th early am for Carlisle.
Leave Carlisle for Pittsburgh Sat afternoon to go back to Pittsburgh till Monday am, 31st...
Leave Pittsburgh...head to MD for party at 5 pm......lots of driving.... Monday , 31st...
Visit friends in MD on Sept 1-2 , head to ME via NJ/CT/NH/MA I think Sept 3-5.....
I don't know yet where I am staying as I cross PA on the way to Ohio
and I may be lost in southwestern Ohio / PA for 8/24-25..
or on the 21st as I dash across NY, PA, on the way to Ohio, so if you want me to photo your car and say hello....let me know
I hope we meet at Carlisle....I will phone will my location (Fun Field) once I get there...207-838-5695 cell
Jack
Ohio and PA just like I imagined.....
Jack
Jack Panzica- LT1
Re: Bonjour à tous
Oh! I Will be with my friends of Club Corvette Quebec at the Cap-Code for the labour day week-end, maybe we can meet you?
Keg- Blown
Re: Bonjour à tous
Keg a écrit:Oh! I Will be with my friends of Club Corvette Quebec at the Cap-Code for the labour day week-end, maybe we can meet you?
Hello, you mean Cape Cod ? Perhaps on your way home...I will be back in Maine by Labor Day....I live in Cape Elizabeth, a few miles from Portland.
Have fun....
Jack
Jack Panzica- LT1
12 hours on the road and I am at Carlisle a week too early!
hi great day....12 hours on road.....details later...car ran great, real tired, near Carlisle. may post later but computer not happy
Jack
Jack
Jack Panzica- LT1
How did I get here ? Just driving in the PA countryside and I am on top of a hill overlooking Corvettes at Carlisle. See you on Thursday. I am off for Pitt tomorrow and will be back early am on 27th opening day
Jack. Cell 207 838 5695
Jack Panzica- LT1
Re: Bonjour à tous
Happy fot you , nice trip....enjoy
Alec- Turbocharged
» Bonjour à tous, et tous mes voeux pour cette nouvelle année
» Bonjour a tous
» Bonjour à tous
» Bonjour à tous ...
» bonjour à tous
» Bonjour a tous
» Bonjour à tous
» bonjour à tous
Page 28 sur 29
